Worth: [price_with_discount]
Up your commute recreation with our Automobile Vent Mount Professional that includes official MagSafe expertise. This moveable automotive cellphone holder mount is constructed with the facility of MagSafe to securely preserve your iPhone 15, iPhone 14, iPhone 13, or iPhone 12 sequence cellphone inside view. Like all Belkin MagSafe equipment, this automotive cellphone holder is thoughtfully designed, and constructed to final. The Belkin Vent Mount Professional makes use of MagSafe expertise to make sure a simple and correct magnetic alignment, so your iPhone stays safely mounted by all of the highway’s bumps and turns. A high-quality base and durable vent clip make sure that your Automobile Vent Mount Professional with MagSafe stays safely in place. Our MagSafe Automobile Vent Mount rotates utilizing a high-quality ball joint, so it’s simple to flip from portrait to orientation with one hand. With the built-in cable administration system your playlist, instructions, and calls gained’t be interrupted, and retains your charging cable neatly organized and inside attain. The Automobile Vent Mount Professional with MagSafe works with official MagSafe instances, simply set your iPhone 15, 14, 13, 12 sequence machine, case and all, in opposition to the magnetic floor and go. (Automobile charger cable, and energy provide not included).
DURABLE AND SECURE: This MagSafe licensed cellphone mount for automotive is manufactured from high-quality supplies, securely maintaining your MagSafe appropriate cellphone in place whereas driving
POWERFUL MAGNETIC CONNECTION: The Magsafe appropriate automotive vent mount makes use of Magsafe expertise to make sure excellent alignment. Even with one hand the embedded magnetic system permits you to simply place your iPhone on the charging mount with none problem
CHARGE IN ANY POSITION: View and cost your cellphone in portrait or panorama mode for optimized entry to navigation, music playlists, and calls, all whereas maintaining palms free
BUILT-IN CABLE MANAGEMENT: Handy built-in cable administration retains your charging cable organized and inside attain. (Charging cable and energy provide bought individually)
