Worth: [price_with_discount]
The SoundLink Revolve+ II is engineered to ship true 360° sound for constant, uniform protection. Place it within the heart of the room to present everybody the identical expertise. Or set it close to a wall and sound will radiate and replicate across the room, immersing you in that very same feeling you felt at your favourite present. The tapered cylindrical form and versatile material deal with make this Bluetooth speaker straightforward to seize and go. Its sturdy aluminum physique gives worry-free safety, and its water- and dust-resistant design (IP55 ranking) helps you to hold the celebration going, even when it will get splashed by the pool. The rechargeable, lithium-ion battery performs as much as 17 hours — for full-day listening. Voice prompts discuss you thru wi-fi Bluetooth pairing, and you may simply take calls with the built-in speakerphone. You possibly can even entry your system’s default voice assistant proper out of your speaker. Join the speaker to an Amazon Alexa-enabled system, just like the Echo Dot, for much more management. Pair two SoundLink Revolve audio system in Occasion Mode for extra efficiency. Strive Stereo Mode the place devices and vocals will naturally separate and unfold throughout an immersive soundstage — making your music sound and really feel as it ought to. Bose SimpleSync expertise helps you to pair the Bluetooth speaker with a member of the Bose Sensible Household to play in sync. The Bose Join app helps you handle your units, unlock options, and entry future updates. You possibly can simply cost the speaker through Micro-B USB port. And the auxiliary enter lets you hook up with different audio sources. This cell speaker is accessible in Triple Black or Luxe Silver. Included: SoundLink Revolve+ II Bluetooth speaker; USB cable; wall charger.
IMPROVED BATTERY LIFE: With as much as 17 hours from a chargeable lithium-ion battery, you get extra play time than the unique SoundLink Revolve-plus speaker. Charging is simple through the Micro-B USB port
DURABLE PORTABLE SPEAKER: SoundLink Revolve-plus II is mud and water-proof (IP55 ranking), so it’ll stand as much as splashes by the pool. Plus, it’s straightforward to seize and go, with a versatile material deal with
BUILT-IN MICROPHONE: Take calls and entry your system’s default voice assistant proper from the transportable speaker. Or join the speaker to an Amazon Alexa-enabled system, just like the Echo Dot, for much more hands-free management of your music
CONNECTING IS EASY: Voice prompts discuss you thru pairing your system to this Bluetooth speaker. Multi-connect helps you to pair two units at one time and simply swap between them for full management of the music
BOSE SIMPLESYNC TECHNOLOGY: SimpleSync pairs your SoundLink Revolve+ Collection II to appropriate Bose merchandise for sound that follows you. Press and maintain the Bluetooth button on every system to sync their sound. Hyperlink extra units by urgent the Motion button.
