Value: [price_with_discount]
Product Description
Chord Electronics Mojo 2 DAC and Headphone Amplifier
Mojo 2 is essentially the most superior DAC/headphone amplifier on the earth. It performs your favorite music with class-leading element and readability, proper as much as studio-grade ranges.
The British designed, engineered and constructed Mojo 2 is essentially the most superior transportable DAC and headphone amplifier on the earth.
DAC and Headphone Amp in a single highly effective package deal
Revolutionary DAC with Cell Lossless DSP
Distinctly completely different from all different gadgets, Mojo 2 makes use of proprietary British digital audio know-how perfected over greater than 20 years, coupled to a strong ‘FPGA’ processor. The result’s class-leading sound high quality each on the transfer or at residence, with the facility to effortlessly drive any headphones. For music simply because the artist supposed, Mojo 2 brings you nearer to the music than some other transportable
Distinctive FPGA Know-how
For greater than 20 years, Chord Electronics has completely used highly effective programmable (FPGA) circuits with customized coding to supply essentially the most superior digital-to-analogue conversion efficiency on the earth. Mojo 2 incorporates extra digital audio know-how than some other small DAC, leading to unrivalled sound high quality, all backed by peerless technical measurements from the lab.
Wi-fi Prepared with Poly
Fully appropriate with our Wi-fi streaming module Poly, Poly permits for wi-fi integration to your system
Distinctive Advantages Unrivalled digital audio processing; highly effective ‘FPGA’ know-how Extra USB-C knowledge enter for quick data-transfer Absolutely clear ‘Extremely HD’ digital sign processing EQ, tailoring the sound to you Take Mojo 2 wi-fi when including the Poly streamer/server (2 TB) Proudly made in Britain from aircraft-grade aluminium. Anodised, bead-blasted, precision CNC milled. Improved Battery: FPGA-controlled administration plus improved capability New menu button with further management sphere Improved WTA filtering: 40 DSP cores for higher transparency and decrease noise
Technical specs:
Inputs Coaxial, dual-data coax, optical, Micro-USB and USB-C Dynamic Vary 125.7 dB A wt Noise 2.7 uV A wt., no measurable noise ground modulation Distortion 0.00027 % at 2.5 V 300 ohms Energy Output 90 mW 300 ohms (5.2 V RMS), 600 mW 30 ohms (4.2 V RMS) Output Impedance 0.06Ω Output Ports Two 3.5 mm headphone jacks WTA Filtering 40 DSP cores providing 40,960 faucets Extra: 118 dB stereo separation 1 kHz 300 ohms 2.5 V
1x 3.5mm Jack Coaxial 768kHz/32-bit Succesful Enter
1x Optical TOSLINK 96kHz/24-bit Succesful Enter
1x 1amp Micro USB Charging Port Enter
2x 3.5mm Headphone Jacks Output
