Apple needs you to keep away from damaging your listening to if you’re utilizing an iPhone or iPad (however, unusually, not a Mac). In Settings > Sounds & Haptics > Headphone Security, allow Scale back Loud Audio, and you’ll set a threshold above which your iPhone or iPad will average sound. It doesn’t create an abrupt cutoff, however it retains you from listening to sounds above a selected stage, measured utilizing customary decibel items.
Nevertheless, when you allow this setting, it impacts all exterior audio gadgets, not simply wired and wi-fi headphones and earbuds. As a result of Bluetooth doesn’t permit a cellphone or pill to know what’s linked, simply the sort of Bluetooth information requested, Apple throttles the utmost sound to all Bluetooth gadgets, together with externally linked audio system.
Headphone Security affords a single setting that impacts all output by way of wired headphones and earbuds and all wi-fi connections over Bluetooth.
Foundry
Foundry
Foundry
Should you forgot that you just enabled Headphone Security otherwise you anticipated it wouldn’t have an effect on exterior audio system, your thriller is now solved. My partner and I troubleshooted the issue when it turned out my cellphone may produce a louder quantity to an exterior Bluetooth speaker than hers: she had Headphone Security on, and I didn’t.
Apple allows you to categorize Bluetooth gadgets in Settings > Bluetooth > gadget identify > information icon > Machine Sort. However Headphone Security doesn’t seek advice from that selection when you’ve set it, nor does Apple present that sound is being throttled when the security function is turned on.
Ask Mac 911
We’ve compiled an inventory of the questions we get requested most regularly, together with solutions and hyperlinks to columns: learn our tremendous FAQ to see in case your query is roofed. If not, we’re all the time in search of new issues to resolve! E-mail yours to mac911@macworld.com, together with display captures as acceptable and whether or not you need your full identify used. Not each query shall be answered, we don’t reply to e-mail, and we can not present direct troubleshooting recommendation.
Supply hyperlink
